westy
Fuel Guage Doesn't Work.
westy
Hey,
I've bought myself a little project for the summer, and one of the fist things to do it get the fuel guage working. I suspect its just the connector thats ome off - Where is it located? is it easy to get to?
Thanks!
jonD6B
It's under a large round black grommet in the floor pan above the fuel tank next to the fuel pump iirc.
westy
Sorry, i meant on the dashboard end :)
Connection to the clocks is under the insturment cowl, if the fuel guage has stopped working have you checked the fuses as I'd be surprised if the connection has come off the clocks & thats all that isn't working. (I think it should be pin #5 on the white plug, possibley a blue wire).
Graham.
westy
Graham.
Any ideas which fuse it would be?
Result of trying a searchanimated1yr.gif. :( :(
Graham.
westy
Graham.
shocking stuff :P
well, considering that everything else works apart from that, it could be the other end?
