Guest lombardo
High Idle.
Guest lombardo
Hi,
My car idle's at 2,000 rpm. On pushing the throttle pedal down it goes to 3,500 revs then a blip of the throttle then it goes down to 2,500-2,000.
What is the cause of this, im am baffled. Everything looks ok underneath the hood?
Would a fast idle also cause a high temp?
Edited by lombardo
j_turnell
Sounds like an air leak, check for a split pipe or loose clip etc. Missing oil filler cap bolt is a favourite. A search may also help....
jonD6B
A high idle won't cause an excessively high temp although it will get upto temp. quicker whilst stationary.
