Guest darren1984
She Wont Go Into Gear(clutch Lever?)
Guest darren1984
Hi guys!
I have a 205 gti with a gti-6 engine and 1.6 gearbox and the car simply wont go into gear..ive tried adjusting the cable to both extremes and you have to shove it into gear with some force,i have had a search on here about the clutch lever but what exactly goes wrong with them?..what was other peoples experiences if this happened?
Thanks alot
Darren
huxley309
Sounds to me like the rings that disengage the gears are siezed and so arent allowing you to engage the gears
Seems like a rebuild to me mate
Guest darren1984
it feels like the clutch isnt quite engaging enough like,whilst in gear its grand,smooth etc,no jurkiness etc
huxley309
Ok that ones got me stumped maybe the release bearing isnt sitting on the fork correctly
steve@cornwall
had a be1 where the clutch arm was bending , also a bitch to get in gear and didn't really know until the arm broke. replaced the arm and ran fine for another 2 years!
Guest darren1984
was it hard to take the arm off steve?
steve@cornwall
just release the cable and one large bolt through the centre! In fact it makes it easier to remove the starter bolts if you take the arm off-very easy
Edited by steve@cornwall
Guest darren1984
has anyone got any pictures as im a little lost!,lol!
ablister
is it going into gear with the engine switched off?
Guest darren1984
yeah it goes into gear no problem when the engine is off
ablister
Doesn't sound like the gearbox is faulty then, more clutch related
Guest darren1984
I have removed the cable and the lever is very loose,is it suppose to be like this?,and i cant really see how it comes off,i can see like the end of a threaded nut but have no clue on takin it out,is this the pin?
Thanks alot
Darren
ablister
that pin is a pain to get out, it is supossed to just pull it out but it never happens.
What do you mean by the lever being loose? Play in the fork + shaft or that it can turn easily? It's ok if it moves round a little but you are not supossed to have any play in the bearings. The bearings aren't expensive (£2 ish each) but the box needs to come out.
No idea if that's what's causing your problem though
205Rog
Try starting the car in gear with the clutch down if it jolts forward, the clutch plate has rusted to the flywheel.
Keep trying the starting in gear method with the clutch pedal should eventually free itself. Had this on my 205 only yesterday!
Guest darren1984
yeah,if you start it in gear with the clutch down,it doesnt jump forward,you can take off really smoothly by releasing the clutch,just cant get it into gear.lol
jacobs53
I had this on my old 205. Would crunch into all the gears when first started. Never understud why?
lee
Guest darren1984
lee
is it a gearbox out job to do the thrust bearing?
