Guest frew
Wobble Under Acceleration?
Guest frew
Hi, ive used the search fuction and seen a cople of topics regarding this and have tried everything mentioned but its still there!!
Im getting a wobble through the wheel on acceleration mainly in second and a little bit in third, there is no vibration after about 50 mph and it only happens when accelerating.
Ive just yesterday finished quite alot of work on the car replacing both front wheel bearings, fitting new springs, group a top mount rubbers, bearings and both driveshafts (new).
The vibration was not there before i done the work to the car. I have checked the gearbox bolts are tight and had the tracking done this morning and the vibration is still there!!
Any ideas would be greatly appreciated.
Cheers Graeme
Craigb
are the hub nuts done up to the correct torque? and the bearings seated properly ?
And a daft one wheel nuts ?
Guest frew
Hub nuts have been checked and wheel nuts are brand new and tight.
Any chance it could be a duff driveshaft or the diff it the gearbox playing up?
Craigb
Don't know ...
first thing i would do is get the front end in the air on stands and give all the moving parts a good tug ..
the wheels have been balanced haven't they ?
Alastairh
Just check,
Wheel balancing
Check everything is torqued up right
Engine mounts
Banjo
Mine does this and its the driveshafts, so i'd be tempted to say duff shaft mate.
Ben
DaveK
what about the tyre pressures mate? i get wobbling on my vectra cos i have a slow puncture and it wobbles when it gets too low. Also have u lokoed at the wishbone bushes and ball joints?
could be the ball joint that has went kaput if uve taken the hubs off
Guest frew
Thanks for everyones input so far, gonna have another look tomorow.
Will check everything mentioned and if all else fails i recon it could be a duff driveshaft and i will need to live with it for a while!
Cheers Graeme
jim205GTI
Someone please correct me if i am wrong but if the discs weren't true and flush to the face of the hub could this also cause the vibration?
jonnie205
drive shafts 100%
Banjo
jonD6B
I'd also check the shafts for condition and location.
