Guest antgel
Inlet Manifold Seals
Guest antgel
I have to take the inlet manifold off to replace the starter motor. Haynes states:
"Undo the manifold retaining nuts and withdraw the manifold from the engine compartment. Recover the four manifold seals and discard them; new ones must be used on refitting."
Do they mean the manifold gasket? I bought one, but it's a single piece, not four.
PumaRacing
The TU engine has rubber seals. The XU has a single manifold gasket. Are you actually reading the right section of the manual for your engine?
kevcomdude
I have some Inlet manifold gasket spare, if you need them ?
could either pick up from Maidenhead, Berkshire, or I can send them to you.
