Bassman
Pas Ram Leaking
Bassman
Got the car up on ramps and have found my PAS leak. The fluid is coming out the top of the ram, I haven't removed it yet (had to buy a 55 TX bit), but will take it off tomorrow.
Can these rams be taken apart and re-sealed?
I was looking at one on eBay for a 306 which is identical, but it is at 41 quid now, anybody know what they go for at a scrappy?
Ta
Never taken one apart as I just replace them if needed, They come off without too much hassle but make sure you don;t break the metal pipes, I;ve got loads of good rams if needed
saveloy
Many a time the bushes secuting the rams in fail and cause movement and leakage. If it isn't too far gone it may simply need new bushes.
Bassman
Cheers guys, I'll get it off and have a look. Miles I'll PM you about a ram if need one thanks.
huxley309
As saveloy said could be worn bushes but they're nothing to replace
If it is the pipes and the bushes get them from pug,last time my pipes went the set they supply were greatly improved :)
