Grim.Badger 15 Posted May 10, 2006 I've got two questions here. Firstly, according to the receipts that I inherited, I have an Apollo 2002 (Thatcham Cat 2) immobiliser. Is this model any good? Is there anyway I can check if it is what it says? Also I was wondering if someone could tell me which alarm systems are any good - cheap but not sh*t and that doesn't go off every 5 seconds Cheers. Share this post Link to post Share on other sites
TEKNOPUG 3 Posted May 10, 2006 Look for one with a transponder - they are a lot less hassle. Unfortunately the insurers will demand that it's fitted by a "certified agent" - which will mean that you'll be charged £100 for a bodged job - the usual cause of most problems. I've found Clifford to be nothing but a pain in the arse from my experience. Best just to rig your own immobilier (cut into the ignition system and mount a switch somwhere out of sight), once you got a certificate to give to the insurers. Share this post Link to post Share on other sites
