petert 601 Posted May 10, 2006 There's been plenty said on this forum about 16V oil control. Here's how I do it, after fitting a 15mm spacer to a trap door alloy sump (either 1.9L 8V or 2L) and topping up with 6.5L of oil. A ring, the same shape as the pickup is cut out of aluminium plate on a CNC mill. The plate is then TIG welded to the pickup. Socket head cap screws are used to retain the screen and cover. This allows complete cleaning of the pickup in the event of any more mishaps. If you're good enough to get oil surge after using this setup, together with a windage tray, you need a dry sump solution. It's a tried and proven race car solution. You can purchase either just the ring, or a completed pickup sub-assembly. Share this post Link to post Share on other sites
Kitsune 0 Posted May 10, 2006 How does this help (for the simpletons amongst us)? Share this post Link to post Share on other sites
Anthony 1,003 Posted May 10, 2006 How does this help (for the simpletons amongst us)? In simple terms, the deeper sump and extended oil pickup mean that you have approximately an extra 1.5 litres of oil in the sump, and the baffles help to keep the oil near the pickup. Or in other words, it's much more difficult to get to the point where there's no oil around the oil pump pickup which causes oil starvation. Share this post Link to post Share on other sites
Kitsune 0 Posted May 10, 2006 I see, I wasn't aware that the the 8v sump was 'deeper'. But having read through that again properly, and seeing that a 15mm spacer plate has been fitted, it makes sense now. Having one of those moments! Share this post Link to post Share on other sites
Anthony 1,003 Posted May 10, 2006 I see, I wasn't aware that the the 8v sump was 'deeper'. But having read through that again properly, and seeing that a 15mm spacer plate has been fitted, it makes sense now. You have to be a bit careful, as in the UK the 1.9 GTi (XU9JA/XU9JAZ) sumps are the shallow design like Mi's, whereas they're deeper (like 1.6's) over in Austrailia. Basically you need a petrol sump other than a 1.9 GTi or 1.9 Mi16, and you need the spacer/stiffener from the 1.9 GTi or 1.9 Mi16 Clear as mud? Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted May 10, 2006 I won't ask how you know which sump is fitted to an Aussy 205! You geek you Share this post Link to post Share on other sites
saml666 0 Posted May 10, 2006 Glad I found this thread, it was referred to elsewhere... Erm, being a real pug newbie I don't know for sure what I have and where to special bits, so, any chance you could put a shopping-list up for the bits I need, already have and where I can get them. I have a 1.9 alloy block Mi16 engine and a knackered 1.9 8v - do I take it though that I need a sump from somewhere else completely? Both sumps had spacer plates - hey, could you just double up on those? I have a brand new oil pump and 2 old ones to practice with, can anyone sell me the bits I need? Sorry to sound dumb, but, er, I am I guess Cheers, Sam Share this post Link to post Share on other sites
petert 601 Posted May 11, 2006 Sorry, I forgot our sumps are different. I am referring to the 1.6L A/C alloy sump, which is the same depth as the 2L sump. Neither had the 15mm spacer plate. If you can weld Sam, I can sell you the pump extension. It only weighs less than 100 grams, so it's cheap to post to the UK. Share this post Link to post Share on other sites
Bonzai 2 Posted May 11, 2006 i'd be intrested in one peter Share this post Link to post Share on other sites
petert 601 Posted May 11, 2006 i'd be intrested in one peter no problems, $40 plus a few bucks for postage. Share this post Link to post Share on other sites
Kitsune 0 Posted May 11, 2006 Would it be worth trying a group buy? Share this post Link to post Share on other sites
Mandic 0 Posted May 11, 2006 I have made same mod myself, took a pipe of pickup lip diameter, cut it, and filled the gap with a plate and then weld it all up and grinded the surface until it was flat. costed me 20 quid. Cheers Ziga Share this post Link to post Share on other sites
Man3 0 Posted May 11, 2006 I'd be interested in this, can you pm me with details for payment etc. Share this post Link to post Share on other sites
saml666 0 Posted May 11, 2006 Sorry, I forgot our sumps are different. I am referring to the 1.6L A/C alloy sump, which is the same depth as the 2L sump. Neither had the 15mm spacer plate. If you can weld Sam, I can sell you the pump extension. It only weighs less than 100 grams, so it's cheap to post to the UK. Well I know a man that can, so at the risk of sounding stupid (except I do it all the time) what model should I be looking for in breakers here in the UofK to get a deep sump? Also, can you supply a diagram of the baffles atall? Or again which sump / part nos to take to Peugeot. Sorry to lay so many questions on you but I'm eager to get this right - am also going to try Cartooners new oil drain from the head by drilling the block. I'd be happy to play host to a group buy also (is that how it works?) so if anyones interested PM me (or is it Peter, am I being too keen?) Cheers, Sam Share this post Link to post Share on other sites
Bonzai 2 Posted May 11, 2006 you need an xu10 sump (gti6, s16 etc). i think miles has some. ive sourced one from psooc hence me needing this pump spacer. its either this or run without a sump spacer which has unconfirmed results as far as i could gather. Share this post Link to post Share on other sites
Bonzai 2 Posted May 12, 2006 no problems, $40 plus a few bucks for postage. so thats about £20 or so? what are your thoughts on group buy? i imagine theres not much money to be saved with something like this? Ben Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted May 12, 2006 so thats about £20 or so? what are your thoughts on group buy? i imagine theres not much money to be saved with something like this? Ben I think 40$ AUS is more like 16.5-17£ Share this post Link to post Share on other sites
petert 601 Posted May 13, 2006 Sorry, I couldn't possibly do a group buy on this. $40 is approx. £17. The mat'l costs $10 alone. All I can say is that's it's extremely well made. A CNC mill spots the centres for the eight holes, then cuts out the profile. The holes are tapped 1/8" BSW. If you just buy the extension you would need to use it as a template, drilling 2.5mm holes into the screen and cover, later enlarging to 1/8". Share this post Link to post Share on other sites
Bonzai 2 Posted May 13, 2006 yep book me in, i want one 1 Share this post Link to post Share on other sites
James_R 3 Posted May 13, 2006 yep book me in, i want one No you mean two Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted May 14, 2006 Is that £17 for the ring alone, or for the pick-up extension with ring welded to it? Share this post Link to post Share on other sites
petert 601 Posted May 14, 2006 $40 for just the ring, $80 for the assembled pickup. Share this post Link to post Share on other sites
Rik 0 Posted May 15, 2006 Peter - how about some contact details? i have paypal Share this post Link to post Share on other sites
