BERTMAN
205 Xs, With Gti Suspension....
BERTMAN
I want the front suspension from a GTi on my lil XS and would like to know what might (and most probably will) go wrong... ie will the subframe bolt straight on?, 1.6 or 1.9 hubs?, ive also been hearing horror stories about gear linkages too...
any info welcome... :P
danpug
Subframe will bolt straight on, i'd personally try to get hold of 1.9 hubs to allow for easy brake upgrades. Can't see what issues there would be with gear linkages providing you use the gti rods??
BERTMAN
will GTi linkages fit a MA box? dont gti's have lift up reverse, and MA's dont...
Jer309GTi
Only the earlier GTi's have lift up reverse. The linkages are different between GTi's and TU engined cars. I did a long search because I was planning to do this to my XS.
Heres a couple of topics...
search
search
Hope this helps :)
BERTMAN
ace, thats really helpful thanks :)
BERTMAN
slightly off topic here but would a 309gti rear axle rub excesivly on an XS with 15" speedlines, as its got a wider track?
Ahl
Yes, it would. 15" speedlines on an XS rub with the standard beam anyway.
BERTMAN
well if i had a 309gti axle on it, how could i stop it rubbing?, roll the arches? if so whats that invole?
Ahl
No, you'd need to seriously cut away the arches and put something like add on Rallye arches over them.
