Guest Tidybri
Rubbing Arches
Guest Tidybri
Not long had my Pug and noticed it had slashes out of the pasenger rear tyre. Is this a common problem when fitting 1.9 alloys on a 1.6?
Do i need to do something with the arces or something????
Any help is apreciated thanks
Jonmurgie
I take it the car is lowered... quite a lot? It shouldn't rub so there's definatley something up there
Guest Tidybri
no it aint been lowered!!!
i guess the previous owner has messed with something to make it like this??
Wot are the options here then?
Jonmurgie
Can you get a picture up?
Guest Tidybri
At work at the mo will try and do it after lunch if i can.
does the pug have a torsion bar cld this be the problem? thats wot a m8 of mine said but he is no expert
This is the best pic i can get at the mo mate sorry is it any use?
Is it rubbing on the outside or inside of the arch? All of these cars at at the age where the rear beam is failing and allowing the wheel to camber and rub on the inside arch - the excess negative camber should be obvious if you look at the back of the car (or feel between the wheel and inner arch with your fingers)
trickywoo
I've got 1.9 alloys on a 1.6 with 195/50/15 tyres and there is a reasonable gap on the inside (no rubbing).
As said above that is a possible symptom of a knackered beam. If you also have creaking noises or a stiff ride at the back then thats your problem.
Guest Tidybri
Oh that sounds like a expensive/big job 2 fix?
Will check it out when i get home later, it rubs on the top on the outside there isnt alot of room towards the front edge of the arch either
Edited by Tidybri
maturin23
Measure the track width - could be a 309 rear beam.
Mine is (and a strip-down showed that all was well with the bearings) and with the height set a little too low the wheelarch chews a bit out of the tyres.
Guest Tidybri
IS THIS AN EASY THING TO DO CAN I NOT JUST MAKE IT HIGHER THEN??
Simes
From the picture it looks high enough.
looking at the rear of your car from about 20m away, do the wheels look like this / \ or / | or | \ ?
Guest Tidybri
Haven't been able to get a good look today but think maybe l \ so is that bad?
i guess so so wots mu next step can i just swap the hole thing and maybe upgrade to disks?
Guest Tidybri
Well finaly got chance to take a proper look today!!
Seems the previous owner had put spacers on the rear!!
Now removed them hopefully this will solve my problem if not will have to think again.
Garry
Also, check that both bumpstops are present. They are small rubber cones fitted to the chassis, just in a bit from the wheel arch. I lost one of mine and when hitting big bumps the wheel would touch the arch.
:(:huh:
I know of people that have found this before & the spacers were fitted because the wheel was hitting the inner wing due to the beam bearings dying.
Hope its not the case this time though. B)
Graham.
Guest Tidybri
worse thing is car is sorn at the mo till the end of the month so cant take it out to try it.
will let you know when i can maybe one night this week.
Do hope its ok cant really afford to recon the beam is it cheaper to replace the whole thing and can i fit disks as a straight swap? would like disks all round really.
