driversdomainuk
4900342 Cat Cam
driversdomainuk
Hi
Just been advised by the boys at QEP that my 205 1.9 8v running 45s (used for hillclimbs) would be suited to a 4900342 catcam.
Do I need the CR increasing on this one..? I am getting new springs and retainers as part of this package - just over £300 + vat
Also, they have quoted £80ish for a venier pully - is this really needed....????
Thanks guys
Definitely 11:1 min. for that one.
You wouldn't know about the pulley until you fitted the cam. If you're fitting the cam yourself, then it's only your time. But if you're paying someone else it's probably cheaper to do it once.
The PSA Group A cam I once had, dialled straight in at 106 deg. with the standard pulley. Who knows with a non OEM part.
Edited by petert
309PUG
It's the same cam that I have, go for 11.5:1 CR and definately get a vernier pulley.
