Guest yaztromo Posted May 1, 2006 My 1.9 engine pinks under load so I had a mobile engine tuner out to it today. He retarded the timing and discovered that the mixture was too lean; it was only giving 0.5% CO2 on the exhaust, so he increased the mixture to 1% CO2 emissions. He told me that the vac advance is incredibly weak but said that I really shouldn't replace it because it would hardly help at all. Is this right? Does the vac advance change very little? Share this post Link to post Share on other sites
Henry Yorke 269 3 Cars Posted May 2, 2006 They are only about £18 from Peugeot. It depends how he has tuned it too. You will find it a bit sluggish low down if he has tuned it for the advance state. You have to think that these things are often there for a reason! Share this post Link to post Share on other sites
petert 601 Posted May 2, 2006 vacuum advance = better fuel economy Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted May 2, 2006 If it is pinking mi-range and it is a standard engine then the bob weight are probably giving too much rev related advance (or to look at it another way they are giving the right amount of advance just at too low a revs). Probably due to duff bob-weight springs. However, the dizzy is "not servicable" so another dizzy may be the answer to your woes or do a search on here as it is possibnle to get the dizzy apart but it is a bit of a mission. Rob Share this post Link to post Share on other sites
kyepan 291 Posted May 2, 2006 He told me that the vac advance is incredibly weak but said that I really shouldn't replace it because it would hardly help at all. Is this right? Does the vac advance change very little? when I replaced the dizzy for one in the scrapyard its vac advance was damaged... so i changed it, and all the dodgy idle problems i was having miraculously dissapeared. for the price of the part and the ten minutes it takes to get the new one seated correctly i think it was worth it. JB If it is pinking mi-range and it is a standard engine then the bob weight are probably giving too much rev related advance (or to look at it another way they are giving the right amount of advance just at too low a revs). Probably due to duff bob-weight springs. However, the dizzy is "not servicable" so another dizzy may be the answer to your woes or do a search on here as it is possibnle to get the dizzy apart but it is a bit of a mission. Rob Scrappy will definitly have them and its only 2 bolts to get them off, but its a lottery as to whether you will get the right fitment cap.. as boshe dizzy has two fitments, and dulcuier may also have two. also you will need the right dizzy, as the 1.6 and 1.9 have different advance curves.. whatever that means. Justin Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted May 2, 2006 Advance curves (on a GTi dizzy): the amount of advance added by motion of the bob weights with relation to revs. Share this post Link to post Share on other sites
hengti 2 Posted May 2, 2006 vacuum advance = better fuel economy my understanding too thought the function (or not - !) of vac adv has no affect on power (or pinking) - only part throttle fuel economy Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted May 3, 2006 It certainly can effect pinking but it is not usually the cause. It gives more power on a trailing throttle and hence better fuel economy as on a cruise you use a trailing throttle most of the time. As it only makes a difference on a partly closed throttle it does not effect the headline power. Share this post Link to post Share on other sites
Guest yaztromo Posted May 3, 2006 It certainly can effect pinking but it is not usually the cause. It gives more power on a trailing throttle and hence better fuel economy as on a cruise you use a trailing throttle most of the time. As it only makes a difference on a partly closed throttle it does not effect the headline power. In that case I'll probably not replace it. I was just worried it was losing me bhp. Share this post Link to post Share on other sites
petert 601 Posted May 4, 2006 In that case I'll probably not replace it. I was just worried it was losing me bhp. So you're not interested in part throttle torque? It's either idle or WOT? Share this post Link to post Share on other sites
Guest yaztromo Posted May 4, 2006 So you're not interested in part throttle torque? Good point. It's either idle or WOT? What's WOT? Share this post Link to post Share on other sites
