Guest Tom Dimma Posted May 1, 2006 Hi does anyone know how i can get my wheels to line up with the arches as i am having a Dimma kit fitted to my peugeot 205? ive got about a 4" inch gap on the front and a 6" gap on the rear. i am having a 309 rear tosion bar fitted so the rear will be pushed out about 1.5" each side Any help will be gratefully recived or has any one got a set of really wide wheels. Thanks Share this post Link to post Share on other sites
Banjo 1 Posted May 1, 2006 Buy some decent wheels.. (Read WIDE) Share this post Link to post Share on other sites
DaveW 6 Posted May 1, 2006 what wheels are you trying to fit? Share this post Link to post Share on other sites
Guest Tom Dimma Posted May 2, 2006 i have found out the offset of the wheels i need they are ET 0 on the front and ET -32 on the rear the problem i face now is im having a 309 torsion bar fitted and this will effect the rear offset any ideas what i will need? the torsion bar will add 1.5 inches to the rear each side. Share this post Link to post Share on other sites
Guest BrainFluid Posted May 2, 2006 Isnt the ET measured in milimeters? Dont quote me on it but i thought that was the case, and if it is work out how many mm are in 1.5 inch and add or take away the ammout. Hope that helps if its true! Nate. Share this post Link to post Share on other sites
number2301 1 1 Cars Posted May 3, 2006 Are you sure the 309 rear beam is as much as 1.5" on each side? Share this post Link to post Share on other sites
Guest Tom Dimma Posted May 3, 2006 yea im pritty sure ive got x sprot racing building the beam for me and they said it was about that. Share this post Link to post Share on other sites
boombang 2 Posted May 3, 2006 Use 405 running gear? Share this post Link to post Share on other sites
jonD6B 0 Posted May 3, 2006 My 309 beam is only 30mm wider than my 205 one. Measured hub to hub on the outer faces. Share this post Link to post Share on other sites
