Guest ZoomZoom
Is This Normal?
Guest ZoomZoom
I may be being paranoid but is this seal across the car normal?
Edited by ZoomZoom
jonD6B
It's normal. If you're after weight saving remove it. B)
Jonmurgie
That's a clear sign of a cut'n'shut.... nah only joking, totally normal as jonD6B points out B)
RobMGti
Yep B) all part of the gorgous french finish
I to was worried when i stripped mine out, but looking at some pics on here found it totally normal.
Completely? Is it not there for much of a reason?
Cheers.
Paintguy
It's there to seal the joints, but if you've got ultimate weight saving on your mind, the odd leak here and there won't be a problem.
jonD6B
When you fully strip the car you are going to have holes all over the place. I wouldn't worry about it. :)
