Anton green
Brown Multiplug!
Anton green
Just cleaned up my brown multiplug over the gearbox (you know the one), and now the starter motor wont kick in. Seems like too much of a coincidence not to be related.
Can some one tell me how to get my car to start again plez!
j_turnell
Check the thick blue wire that goes to the multiplug this is the starter wire, probably come loose.
Banjo
Just cut the crappy plug off and through crimp the wires instead, proper job.
Edited by Banjo
Guest chris1993GTI
Totally agree! Gunna do this in the morning with mine. Spent all of today replaceing the full front suspension. Had an hour or 2 left of daylight and thought I'd clean said connector to sort my irratic oil guage......Bugger all works now B) Off it comes first thing :D
Anton green
I had a fiddle around with the multiplug today and particularly the blue wires, and the starter began working again.
Taking the 'if it aint broke dont fix it' approach I left everything as it was..
I cleaned out the multiplug to get my oil pressure guage working again, but no, it still doesnt move. -Any ideas? (when it stopped working it fluttered up and down a few times before resting at 0 where the needle has stayed ever since, if that helps anybody?)
The only thing cleaning it has acheived is that my dashboard now lights up a lot brighter with the red 'stop' and handbrake warning lights..
Edited by Anton green
davemar
I found the wire from the ignition key to the brown connector is pretty flakey and can stop the car from starting. I got round this by installing a relay which this wire drives (a relay requires far less current the a starter solenoid), and getting it to switch a heavier duty wire from the battery to the solenoid. I've never had a starting problem since.
The brown connector isn't always the cause of the problem when it comes to the starter, as I still suffered from the problem without any brown connector fitted! The solution above solved the problem.
Banjo
Yes the solenoid wire quite often burns out, i've replaced mine with uprated cable, no probs since.
Ben
Anton green
Yes the solenoid wire quite often burns out.
Can you remember which colour wire this is so that I can check on the condition of it in my pug?
its usually blue and slightly thicker than most of the other wires in the brown multiplug.
