matty_gti 20 Posted April 28, 2006 When i went to check my spark plugs today i relised that there all black (dry black carbon i think, not oily) with the electrode black and the just the little arm that goes over the electrode has a white tip?. i know that the running on the car is down to this but what?, Any ideas?. P.S in the book it said 17NM to torque up the plugs, seems a bit tight? Share this post Link to post Share on other sites
notamondayfan 44 Posted April 28, 2006 have a look in the bk of ur haynes manual, theres page or two on spark plugs. Share this post Link to post Share on other sites
Ahl 4 Posted April 28, 2006 17NM isn't tight at all, its literally just 'nipping' them up. The haynes manual does have a good selection of pics at the back. Ideally you want the electrodes to be a whitey-brown colour. Share this post Link to post Share on other sites
Bassman 1 Posted April 28, 2006 If they have carbon deposits then it is probably running rich and your fuel economy will be suffering. Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted April 28, 2006 It isn't that easy as the mixture can vary across the rev range, and particularly different when cold and at idle. I've had perfectly brown plugs while running 6.5% CO at idle! It is an indicator but black carbon plus white tips is an interesting combination... Rob Share this post Link to post Share on other sites
Bassman 1 Posted April 29, 2006 It isn't that easy as the mixture can vary across the rev range, and particularly different when cold and at idle. I've had perfectly brown plugs while running 6.5% CO at idle! It is an indicator but black carbon plus white tips is an interesting combination... Rob Probably still worth getting somebody with a gas analyser to test it and adjust the mixture as necessary. Especially if you have a "Boost Valve". When I bought my GTi it had an FSE Boost Valve fitted and it was set up to run far too rich. It is much better now, can even get 30mpg on a long run (with a following wind!). Share this post Link to post Share on other sites
