PsychoSimon 0 Posted April 25, 2006 Hi all. Basically john (batoutofhell) has a 605 2.1 td with a mint engine, and a partner van with a poo none turbo 1.9 diesel. Will the 605 one go into it as from what i can see it is an xu? i have also heard of people using the blocks for 2.1 mi16's etc so presume it is? Does anyone know if the 605 engine is ecu controlled? i can see a bosch one on the inside of the wing but it may be abs. Cheers guys, Regards, Simon Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted April 25, 2006 it will fit and it is ecu controlled. IIRC the partner vans use the same loom asthe 306 which is on a big multiplug so easy peasy to take it out and splice the ecu in. Problem may come with the fuel supply, IIRC the 2.1 has a lift pump in the tank but the 1.9 doesnt. The wiring is there though in the van so just a case of bridging it somehow where the multiplug is inside the wing. Share this post Link to post Share on other sites
PsychoSimon 0 Posted April 25, 2006 do you have any idea if there are any woring guides about for this then? I take it that it would be pretty much just make a link loom mi16 stylee? I should think it would be possible to add an extra fuel pump outside the partner tank to substitute a lift pump?, Thanks for your help mate, Si Share this post Link to post Share on other sites
