zander205
205 1.0 Problem
zander205
i own a 205 1.0 xv8
was driving the car when i heared a loud bang and a big ball of black smoke from the exhaust.
when i pop the bonnet the distributor was off, something inside started to rub all around the casing till it cut through the housing. i have since the got 2 other distributors for the same engine and the car is misfiring a great deal, bought new plug wires and plugs and still nothing can anyone help waht can be the problem? :)
I was going to move this to the right section then I realised we dont have one for XV engines :)
The TU section will have to do as thats closest...
Guest ben205
I was going to move this to the right section then I realised we dont have one for XV engines :P
The problem sounds like the order you put your ht's back on your distributor cap. They have to be in a certain order for the firing sequence. Im assuming the haynes manual might tell you. But what id have done was make a note of which ones went where when swapping them.
zander205
i did put them back in the correct position, just the car won't fire at all :P
