matt205xs
Magnex Exhaust
matt205xs
Will a magnex exhaust from an mi 1.9 fit on a mi 2.0???
thanks
Jonmurgie
Well the centre section and backbox will with some cutting 'n' shutting... the manifold won't
matt205xs
sorry thats what i mean, i have a 2.0mi 205 and have seen a 1.9 exhaust system so in theory the front/ middle and back sections should fit onto the manifold.
hengti
you can mate up any 205 exhaust system to whatever manifold you're using - as Jon says though, it might require some metalwork
the only point to worry about is the mani-system connection : start by making sure the mani pipe will sleeve tightly into/over the system pipe - if not you'll have to look into welding a step pipe onto the system
you'll also need to think about the length of the system pipe to make sure enough of it is clamped onto/into the mani outlet and that it's not either too long or too short - otherwise the system mounting points will be moved in relation to the hangers under the car and you'll also either end up with the tail pipe too far out or too far in under the rear valance
recommend mikalor exhaust clamps as well - those u bolt clamp things are 'orrible!
