Leon C
Cambelt/coolant Pump Change
Leon C
I've bought a new cambelt, tensioner and coolant pump. However do I pay a through the nose for a garage to put em on or should I brave it and had a stab at it myself, taking into consideration my fairly novice mechanic skills.
I've been quoted £150 for the labour :P which I think is a bit steep ...So just how hard is it anyway?
Jonmurgie
This was discussed in the last week actually... try a search and some info will come up... some of the members offer to do the change for not too much £££ as it's a case of knowing what to do really... it IS a diy job though, if you fancy the challenge, it takes a while the first time you do it (took me over a day!) but that's just a learning curve!
Leon C
Well looks like i'll be having a go at it then ...Seriously can't afford that much now my insurance renewal is due!
...May be posting another thread asking how to rebuild the head though! :o:)
ALEX
When you put it back together, before turning the key, make sure you crank the engine over by hand (ratchet on crank pulley bolt) just to make sure the valves dont hit the pistons.
The job is straight forward, the hardes part is getting the plastic covers off.
Leon C
Ok cheers.
pugpete1108
done mine a while ago , if you know your way around its not too bad , just get the timing right.
a haynes IS actually usefull for something :P
