Richie-Van-GTi 73 2 Cars Posted April 23, 2006 Im getting desperate for a 1.9 non lambda loom. Can anyone confirm if any other looms are the same, or at least have all the same connectors and ecu plug? thanks Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted April 23, 2006 Well obv 1.6 and 1.9 looms are identical, may also be able to find an early bx gti which shares the same loom. Share this post Link to post Share on other sites
Richie-Van-GTi 73 2 Cars Posted April 24, 2006 will the lambda type looms still fit onto the non lambda type ecu? The loom is gonna be spliced anyway so I'll only be using the bits that I need. Share this post Link to post Share on other sites
d-9 0 Posted April 24, 2006 Depends if your refering to an Jetronic or Motronic lamda system. The two arent interchangable, but if u have a Jetronic ecu with lambda i think its interchangeable with a non lambda Jetronic ecu, the plugs look the same anyways! Share this post Link to post Share on other sites
