willxs
Removing The Stub Pins
willxs
im refurbing a 1.6 beam and was going to stick the 1.9 brakes etc onto it from the shafted 1.9beam on my car.
ive done a search for changing from drums to disks and it all seemed straight forward until they mentioned having to change the stub pins. so basically how is this done? is it anything to do with the alan key bolt in the back?
Cheers, will
Wurzel
They are 'pressed' in. I have knocled them out and in with a lump hammer before but you need to be carefull about not damaging the threads. Fit the old hub nut on the end and hit that.
Pressing is deffo the preferred option though and if they are apart easier to do :)
Like Nick says, protect the end of the stub axle & a lump hammer will easily drive them out.
Tha hardest part about the swap is removing the backplates as the allen bolts holding them to the radius arm can round off as you undo them & cause no end of trouble. If you can get them out Ok though its all easy.
Graham.
willxs
cheers guys, got them off now. easier than i thought :)
Will.
Jim miami blue gti
what are the allen keyholes on the back of them for? :P
willxs
i guess its to turn the pin so the splines line up correctly... so when you press them in, they dont mess them up?
