Danxs
Quick Brake/wheel Size Question
Guest smokinslim
Possibly a difference in the size of the caliper itself, gti6 calipers fit in most 15" wheels but its tight. Perhaps 205 calipers stick out a bit more. Why not ask the seller.
Jonmurgie
You might as well get the proper GTi6 calipers and do the job properly... with that kit on eBay you will need to buy some GTi6 discs and it uses your standard caliper, you can usually pick up a GTi6 setup for around £150 so not that much more really...
GTi6 do fit under 15's obvioulsy, maybe that kit pushes the standard caliper a little too close to the wheel?!
Danxs
ok, thanks alot for the quick answer's, i'll keep an eye out for a proper setup then.
