robgti
Juddering Under Braking
robgti
Hi all. just gt my car back after being stood for over a month and took it out and the only problem i can tell is that when i brake hard the steering wheel judders like mad. could it just be down to warped disks with it being stood? thanks
Jonmurgie
Maybe, or it may just be the lack of use... try doing several really HARD breaking from a decent speed (60ish) and see if that cures it, if not then looks like a set of discs are in order...
deejay391
Id try a few firm braking from 60ish rather than just jump on them... firmly just to clear the crap off the discs and make sure the calipers are all ok the ntake it from there, but i would have thought warped discs :D
robgti
looks like it might be more money going to have to be spent on her. cheers for the replies
Jonmurgie
LOL, you basically just re-wrote exactly what I said?!
robgti
had a blast out on my way to work last night and tried braking firmly. isnt doing it as bad now but think i will change the disks and pads as i have braided brake lines and some dot 5.1 brake fluid to put in.
nick
Grease the sliders on the front calipers first.
Mine juddered like mad with relatively new discs on, I greased the sliders and that cured it, I don't think the caliper was pulling up to the disc square.
Nick
