Alan_M
Gti6 Block
Alan_M
Some of you may know that I have a GTi6 lump in my garage with the aim of making a 2044cc (I think?) lump.
Stripping it down last week has shown me it has a hole about 1" in diameter where the rear mount bolts. I have the piece of block to back on, but from chatting to a few metallurgists today at work, they seem to think welding is bad idea :lol:
So i'm on the hunt for a new block, and was wondering if the lesser 2.0ltr XU lump is the same?
Only worry is lack of oil spray bars, but how beneficial are these?
Anybody know more on the blocks, or spray bars?
DrSeuss
pretty much any xu bottom end will bolt up. The xu10j4r bottom end is being used by b1ack_mi16 and so he can probably answer any questions you have about it.
Any 2L block as said will fit the head, even the Ally 1.8 block does too as found in the 306's and 406's.
Not sure on the spray bar's but the 2L turbo engine has them
Alan_M
I knew any 2.0ltr XU would mate up, just wanted to know if there any blocks similiar to the GTi6. Maybe the 2.0ltr XSi had the same block with spray bars etc.
I'll have dig through the Pug parts CD, but good call on the turbo lump although i'm after a cheap block so that maybe out of the question.
pug_life
s16 block is same IIRC.
its the same for s16/T16 and gti6 i think.
Hilgie
yep...all similair blocks, but the 2.0-8Vs (306XSI) don't have oilsquirters except for the 2.0-8V turbo which does have them.
Alan_M
The XU10J4R I have certainly have oil-squirters, find it in early 2.0 16v 406 at least.
Edit: See my post here: http://forum.205gtidrivers.com/index.php?s...20entry539673
Thanks for that! There are a few 406's in my local scrappy, although I have a feeling that they are 1.8's. The scrappy will probably want more for this engine than what I paid for the GTi6 lump!!!!!
DrSeuss
2ltr 16v bottom end is no better then what you currently have. Its probably worse.
