hexhamstu 9 Posted April 18, 2006 (edited) idles fine, doesnt matter about temp, feels like its getting knocked back at 3-4 struggles to get over 5 adfter this it runs fine. have changed: ign amp dizzy rotor arm crank sensor plugs leads injectors cleaned breather system tried another AFM not sure if it was off an 8v or a 16v though it was just lying about in the citreon garage but behaved exactly the same on the breather system the end of the pipe that goes to the throttle body flys is all frayed and broke, could this be causing the problem? i also found mayonaise in the filler cap, but theres no coloured smoke or anything? help meeeee Edited April 18, 2006 by hexhamstu Share this post Link to post Share on other sites
Simes 248 2 Cars Posted April 18, 2006 Have you changed the ignition amp? Share this post Link to post Share on other sites
hexhamstu 9 Posted April 18, 2006 oh yeah i have forgot to add that. Share this post Link to post Share on other sites
