hexhamstu
Mi16 Running Sh*t From 3-5k
hexhamstu
idles fine, doesnt matter about temp, feels like its getting knocked back at 3-4 struggles to get over 5 adfter this it runs fine.
have changed:
ign amp
dizzy
rotor arm
crank sensor
plugs
leads
injectors
cleaned breather system
tried another AFM not sure if it was off an 8v or a 16v though it was just lying about in the citreon garage but behaved exactly the same
on the breather system the end of the pipe that goes to the throttle body flys is all frayed and broke, could this be causing the problem?
i also found mayonaise in the filler cap, but theres no coloured smoke or anything? help meeeee
Edited by hexhamstu
Simes
Have you changed the ignition amp?
hexhamstu
oh yeah i have forgot to add that.
