lordvader
Intermittent Electrical Issues
lordvader
Hey all.
My 205 has been experienceing intermittent electrical issues for quite some time. They don't stop the car from going, but they can be annoying at times. I was hoping you lot might be able to diagnose the symptoms ?
  1. Left brake light works "sometimes"
  2. The horn works "sometimes"
  3. When I'm braking and indicating, my radio might stop for a few moments
The car has a "new" battery, which I was told was not a very high quality one, could that be an issue ?
Dodgy earths and corroded connectors would be my suspicion - clean them up and the problems usually go away...
lordvader
Where are the earth points ?
The only ones I've come across are on the suspension mounts.
jonD6B
There is a main earthing point to the left of the N/S headlight that's worth checking, it is (iirc) certainly where the earth for the horn is taken from.
Alex G
very likely earth or bad connection related
earth point by rear left cluster and front lights. check those
is also worth checking your fuses are in securely and not corroded
jonD6B
Alex G> Nice Avatar but can you remove it as it makes my car look dull! :lol::lol:
Alex G
Really sorry Jon, ive changed it now :lol:
( i was meaning to change it for ages, i sold that car a few months ago :lol: )
jonD6B
LOL. Just need to get my car as shiny as your last one now! :)
