mikie 0 Posted April 10, 2006 Is there a difference between be1 cables and be3 cables.If so then how much different are they?I have a new be1 cable in the garage but not sure if it will fit the be3 in the miami. Share this post Link to post Share on other sites
Ryan 99 Posted April 10, 2006 I think the attatchment is different at the pedel end. Share this post Link to post Share on other sites
huxley309 0 Posted April 10, 2006 (edited) Yup plus where it sits on the gearbox is different and the be1 is slightly shorter,time for a new cable im afraid Edited April 10, 2006 by huxley309 Share this post Link to post Share on other sites
Guest james205gti Posted April 12, 2006 They are totally diffrent. As the parts department gave me the wrong cable when i was changing mine. Share this post Link to post Share on other sites
steve@cornwall 100 Posted April 13, 2006 I think the attatchment is different at the pedel end. you need to change the clutch pedal for be1 and "jigger" with the fittings at the gearbox end too (put '91 engine / box in my 86 cti- still got the old pedal if you want it! I think the attatchment is different at the pedel end. you need to change the clutch pedal for be1 and "jigger" with the fittings at the gearbox end too (put '91 engine / box in my 86 cti- still got the old pedal if you want it! Share this post Link to post Share on other sites
