Alex G
Mi16 On/off Throttle
Alex G
When im just driving normally and coming to a roundabout, for example, when i let go of the throttle its a little jerky (not the mechanism, but the engine) and then jerky coming back on the throttle. it almost reminds me of the way the 8 valves drive.
it happens at 25000rpm but only because thats usually how i drive my car...it would be the same at 6000rpm.
This is a new revelation as it never used to do this! its just progressively become more noticable
not to mention below 2000rpm the engine/car drives crap!!
any help guys
Cheers Alex.
Whats the condition of the distributor cap & rotor arm like?
Have you run it low on fuel recently & this has happened since then?
Graham.
Rom
OMG ! Sry couldnt resist. Im very interested in this though,as my 8v is horrific sometimes. And id like ot know how to cure the Mi lump im rebuilding should it happen.
Wurzel
Nothing to do with the throttle position switch is it? Perhaps worth checking the set up :)
Knackered bottom engine mount allowing the engine to rock about when you come on and off throttle?
saveloy
Sounds like you could be running lean. This would cause low end/idle running problems and would also account for the jerkiness. Check for any split or loose pipes.
Has your mpg status changed recently?
Alex G
sh*t im so stupid!!!!!!!! :):blush:
i bought a new bottom engine mount a few months ago and immediately called Chaz (V1RDE) and told him how s*it they are (GSF)!!!!!! at least thats a cheap and easy problem to fix!! :D cheers Anthony
incidently my mpg is really good, i regularly get more than 300mile on a tank!!! the cap and arm are pretty new too!
cheers for the replies guys :D
Edited by Alex G
eddie_1.9
Where are you going to get you bottom mount from seeing as GSF's are poo?
Alex G
baker bushings and mountings (Stew). (forum advert)
i bought off him once before and was thoroughly impressed, then i thought i would be a cheap git and get one from gsf....... oh well!......time to do it properly this time
