TT205
Low Oil Pressure - When It's Not
TT205
My gauge shows very low oil pressure yet when tested with an oil filter mounted gauge the pressure is fine - replaced the sensor and still reads low gets worse when engine is warm and - yes there is plenty of oil
Any ideas
Jonmurgie
Must be a dodgy gauge/sender... mine has started doing the same recently :(
jonah
Try cleaning up the connections in the "Infamous Brown Multi-Plug"... solved my oil pressure problems anyway! :D
Guest chris1993GTI
Try cleaning up the connections in the "Infamous Brown Multi-Plug"... solved my oil pressure problems anyway! :lol:
Hi,
I have the same/similar problem. My guage jumps allover the place :blush: I had to drive it from London to Doncaster....Scared to death it was gunna go bang! Where is the brown multi plug located mate :D
Chris.
pug309twin40s
check the connector on the sensor is nice and clean and check the wire goes on it nice and tight.
i had this problem last week, oil pressure was good at idle and low revs but when revs went above 3000rpm the pressure shot straight to the red, no warning light on.
so cleaned up sensor connection and crimped the connection onto the sensor abit tighter as seemed abit loose.
brown multiplug should be around the gearbox, thermostat area.
Guest chris1993GTI
Cheers, I'll check that 2moro!
Chris.
les3002
mine is the same mate, must be a turbo thing lol
TT205
Well amazing as it may sound, the fault with mine was the camshaft!!!
No3 lobe has become No3 'round' as in it's fecked - we got as far as a power run on the RR, it had lost 70BHP and was detonating like fek!
I'll let you know what happens to oil pressure when I have a new cam in
Anyone care to hazard a guess as to how a fekked cam screws oil pressure?
Dave
