DaveK 0 Posted April 6, 2006 recently ive been having alot o probs gettin the 205 starting first time. i replaced the starter motor about 6 months ago and worked spot on for about 4 months. now it sticks half the time and i need to stick it in gear, rock the car and then it will start. what else could be the problem? i really dont think its the starter as its nearly brand new im gonna check the wiring soon but seems a random problem for wiring cheers dave Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted April 6, 2006 Could be the ring gear on the flywheel preventing the starter engaging? Come across this on Triumphs but never a Pug. Share this post Link to post Share on other sites
matty_gti 20 Posted April 6, 2006 hmm, sounds like the solenoid is stuck, this deos happen even with new starters. I had to put my car in gear and rock it backwards and forwards because this then moves the ring gear and starter solenoid. after that it would allways work. failing that, wack the starter with a hammer while trying to turn the car over, it just tries to unstick the solenoid. Share this post Link to post Share on other sites
Jonmurgie 2 Posted April 6, 2006 Agreed that it can only really be the Starter knackered again if it's sticking and worked fine for 4 months... is it covered under any warranty? Share this post Link to post Share on other sites
DaveK 0 Posted April 6, 2006 bollox, i cant find the reciept for the thing. doh!!! Share this post Link to post Share on other sites
jackherer 543 Posted April 6, 2006 im gonna check the wiring soon but seems a random problem for wiring my money is on the wiring, 205 gti starter wiring simply isnt up to the job after 10+ years. when you put it in gera and rock it you could easily be moving the wiring about, next time it doesnt start open the bonnet and reseat the brown multiplug and the connector to the solenoid. Share this post Link to post Share on other sites
DaveK 0 Posted April 6, 2006 ok jack ill give that a shot, hope it works and saves me another 50 quid Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted April 7, 2006 Or use a wire direct from the battery to the solenoid, if you don't have PAS then it is fairly easy to get your arm in there. Share this post Link to post Share on other sites
