rooster 0 Posted April 2, 2006 my wipers packed in the other day and i cant get em to work were do i look fro the relays im gonna check the motor wiring later plus were can i get relays it just stopped working, they did stop a bit back but they started working on there own ?? could it be the motor ceased up let me know your thoughts as this is my daily runner im stuck if i cant get em working cheers Share this post Link to post Share on other sites
Wurzel 16 Posted April 2, 2006 You really need to find out if you have power at the motor before going further. If they were intermittent before, then wiring is the main suspect. I have had a motor pack up on me though a long time ago in my old 1.6. Water had gotten in and corroded it to bits. Other thing to check is the fuse. Share this post Link to post Share on other sites
DrSeuss 0 Posted April 2, 2006 i've killed several wiper motors on my car, if you don't have the plastic scuttle cover on, water gets in and kills them dead, rather quickly. The wiper motor relay is in the fuse box, turn on the wipers and feel for a click. Share this post Link to post Share on other sites
rooster 0 Posted April 2, 2006 which relay is it in the fuse box Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 3, 2006 The blue one. Graham. Share this post Link to post Share on other sites
rooster 0 Posted April 4, 2006 cheers graham ok checked the motor and wiring all ok theres no clicking from the blue relay so im guessing its that or i hope it is were can i get relays like it do maplins etc do these or is it a trip to the scrappy or peugeot Share this post Link to post Share on other sites
rooster 0 Posted April 4, 2006 im really pissed off now i got a new relay from the scrappy no difference could it be the switch in the lever the washer jets work so there must be power or is it seperate my car is grounded because of this and its getting me mad now i have to find a nother motor and this isnt easy round here Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 4, 2006 Yes, it could be the column stalk thats dead. Only one safe way to test it, by replacement. Use a multimeter to check if you have voltage at the plug for it. You could be brave (or stupid) & try using another length of wire & bridging the plug connections for the stalk to see if you can get the wipers working to see if the stalk is dead or not. You have checked the fuse is OK haven't you? Graham. Share this post Link to post Share on other sites
Frequentflyer 0 Posted April 5, 2006 my wipers packed in the other day and i cant get em to work were do i look fro the relays im gonna check the motor wiring later plus were can i get relays it just stopped working, they did stop a bit back but they started working on there own ?? could it be the motor ceased up let me know your thoughts as this is my daily runner im stuck if i cant get em working cheers Hallo Rooster, Am breaking a 1.6 Junior Auto. If you decide that you need any wiper related replacement part or parts, I am sure that I can help. Good luck Roy Share this post Link to post Share on other sites
rooster 0 Posted April 5, 2006 i have checked the fuses and see no blown ones plus the fuse is no 3 i believe and the stereo i have goes through that one and thats working. i have another relay ill try that today then ill remove the motor and get another from my local scrappy if they have one if not ill pm roy for the part. im just thinking its something small as ive done this before ripped things out replaced them and it still dont matter and then you find its a wire ref the stalk the washers work so im guessing power is getting to the stalk as water sprays when you pull back i dont think it would have two power supplies to the stalk ??. my 14 months of trouble free driving has come to an end lol Share this post Link to post Share on other sites
