Rob_the_Sparky 10 Posted March 31, 2006 Anyone found a good permenant solution to this? I've tried new o-rings from Pug and it died quite rapidly, the o-ring expanded so the first time I took the dizzy off I had to throw it away! Only a few weeks after fitting as well. Right now it has a bodged seal in there but is leaking like the proverbial sieve and I'm getting it in the neck for the oil on the drive. Is it just a case of use Pug ones and replace everytime the dizzy comes off or has anyone found a better solution? Cheers Rob Share this post Link to post Share on other sites
Ahl 4 Posted March 31, 2006 I stuck on an O-ring from the garage that was the right size. It's been off a few times and still seals fine. Luck of the draw maybe? Share this post Link to post Share on other sites
