Kenno
Can 1.9 Afm Be Used On 1.6 Gti
Kenno
Hiya, well yesterday I had a massive bang from front end first thing n it was the back plate off the AFM.
Well cleaned it up n used some liquid metal n screws to put it back together n it was backfiring like a piglet.
So have taken the 309 1.9 AFM n adjusted the dial to same setting as the 1.6 will this work ok as it seems fine am just gonna take it out for little spin.
Any advice please
Much regards
Kev
Me bad soss i did a seach n found a few helpful bits thanks but any input would be great. now im off for spin I HOPE
Edited by SR i Kenno
j_turnell
The mixture will be totally wrong, youll need to find another 1.6 one.
simonb
The 1.6 AFM has less tension on the spring than the 1.9 as the 1.9 breathes heavier due to the extra capacity. I would set it roughly correct and then set the CO at idle to about 1.5%.
After that, make sure that the car idles smoothly (if that's possible) and check the colour of the plugs after a decent run (should be a light brown tan). It will be obvious if the AFM is set wrong as your fuel consumption will eithefr be up or down, or the car will either feel bogged down at low revs (spring too loose) or will seem gutless at higher rpm (spring too tight).
If you can't get a decent 1.6 AFM, this is the only advise I can offer. Hope this helps.
j_turnell
Try doing a wanted post for one 1.6 afms are ten a penny. Using a 1.9 afm really wont do you any favours.
1 FAT PUG
i got a 1.6 gti one, can have it for £20 delivered
kevcomdude
Im running a 1.9 AFM on my Phase 1 1.6 engine, it runs fine but did need the mixture screw adjusted to get it to idle properly.
Ahl
It won't be supplying the correct amount of fuel throughout the rest of the rev range too.
The engine management on these engines is fairly clockwork and the AFM itself effectively contains the fuel map, therefore using the wrong AFM is a bad idea and just asking for trouble.
kevcomdude
After reading this does anyone have a working 1.6 AFM they wish to swap for a working 1.9 AFM. I will do the driving if nearby.
thanks Kev
