Revla
309 Goodwood Water Leak
Revla
Hi,
As stated above, have sealed the rear lights but seems to fill up along the inside of the
rear slam panel, seep out of the seam along the width of the boot and run to the seat well.
I've had other 309's with leaks before.... but this is mything me!
Maybe sunroof drain holes blocked - it was under a tree for about a year!
Any help appreciated, otherwise its being broken for parts! (I'm keeping the rear beam though!) :D
Trev
d-9
Drill a few holes under the rear seat so it drains out.
309s always leak.
Revla
309s always leak.
Cheers!
May do that, but i'd rather rectify the cause if possible!
Any other ideas anyone??
Guest andy309goodwood
309s always leak.
hummm im on my second and no leaks yet
have you checked the seal on the rear screen wiper if this is perished it will run into the tailgate and then down thro latch and out of the rear panel
i had this prob but not with water i found my sub's vibrated all the polystiren packing in the tailgate side's that the rear screan bonds too lose lol
Edited by andy309goodwood
d-9
Im on my 5th and 3 have leaked, 1 leaked from new :)
Good tip on the rear screen wiper, I havent thought of that one.
Danxs
mine leaks exactly the same as described here! all the pugs i have owned have, anyone would think it dosn't rain in france...!
Revla
Shame they were buit in England!! :ph34r:
Danxs
meh, still a french mobile! lol
d-9
At the end of the day they are better than 205s, so I guess you can forgive them the odd damp patch.
Not like every 205 out there doesnt have a patch of rust under the back seats anyway :)
Revla
A nice bit of green hammerite on my 205 helped!! :)
Guest lenthepug
I have just traced the leak in my 309 to the rear light clusters. The seal is Knackered and the water was flooding the boot in a heavy downpour. The car still has 2 more leaks so will have to find those now!! Hope this helps
Revla
This is the usual place with 309's.... was my first point of call! ;)
Guest lenthepug
Sorry didnt know this was a common problem, I still have one above the fuse box behind the dash somewhere any ideas where its coming from, is this a common problem???
d-9
Thats almost certainly the windscreen seal, however its also worth replacing the fabric washers that seal the sunroof handle (very cheap from pug) and the washer that seals the arial on.
Guest lenthepug
Thanks,
I will give that a go. :angry:
Simon.
