Guest djuk Posted March 27, 2006 Just bought a new 1990 1.9 GTI and there after some heavy rain there appears to be some water leaking in around the sun roof handle and dripping down. I would assume other people must have encountered this before but is there a known fix for it? Thanks David Share this post Link to post Share on other sites
Dream Weaver 2 Posted March 27, 2006 (edited) Yes, the rubber washers under the sunroof screws need replacing. I used some old record deck rubber slipmats for mine cut up, or just find some rubber washers at B&Q etc. Edited March 27, 2006 by Dream Weaver Share this post Link to post Share on other sites
Guest djuk Posted March 27, 2006 Yes, the rubber washers under the sunroof screws need replacing. I used some old record deck rubber slipmats for mine cut up, or just find some rubber washers at B&Q etc. Thanks very much doesn't sound like much hassle so will get that sorted! By the way you're not Dreamweaver from scoobynet are you? David Share this post Link to post Share on other sites
jackherer 543 Posted March 27, 2006 you can still get the correct fibre washers from peugeot dealers, my local one has them on the shelf for 23p each! Share this post Link to post Share on other sites
greig 0 Posted March 27, 2006 i had the same problem, but on mine the screws were totally rusted meaning i couldnt remove them to fit a new washer. to avoid having to drill them out i used a small bit of clear bathroom type sealant. bit of a bodge but has done the trick! Share this post Link to post Share on other sites
Dream Weaver 2 Posted March 27, 2006 (edited) Thanks very much doesn't sound like much hassle so will get that sorted! By the way you're not Dreamweaver from scoobynet are you? David One and the same Which Scoobynetter are you? Edited March 27, 2006 by Dream Weaver Share this post Link to post Share on other sites
Guest djuk Posted March 28, 2006 One and the same Which Scoobynetter are you? Same name - djuk - I post mostly in NSR Share this post Link to post Share on other sites
richiew205 0 Posted March 29, 2006 More scoobynetters, quality . Sorry to get back on the thread ive changed my seals (got mine from just gtis) and mine still leaks but I think mine is from the aerial. Share this post Link to post Share on other sites
Dream Weaver 2 Posted March 29, 2006 Yes, the aerials leak as well - just put some clear silicon around it underneath. Share this post Link to post Share on other sites
richiew205 0 Posted March 30, 2006 Yeh I have done that but not enough me thinks, on one of my lists to do...... Share this post Link to post Share on other sites
