Guest Mr-Stoner
Help Pug Wont Start
Guest Mr-Stoner
Aright guys i need some help fast :/
my 19.GTi has been running like a pig latley so i decided to do a little cleaning i have taken the inlet manifold off and cleaned and all other parts leading up to the airflow meter
replaced the inlet manifold gasget and put the car back together
and now she wont start :)
any ideas ?
kate205gti
wont start.... just turning over? firing? clicking? need clues B)
my guess would be the connector that goes onto the AFM or the coil if its just turning over, if it just clicks then check the spade connector going onto the starter motor
are you getting a spark do you know? :)
Guest Mr-Stoner
right got the car started and running but i can here a pop from the exhaust
and i have just took the rockercover off and a have found what looks like water in there not a good sign ??
Richie-Van-GTi
compression test if your worried about water in the oil, if compression is good then get yourself an emissions tester and check the fuel air mixtures.
