kyepan
Low Idle And Rough Running
kyepan
Finally got the car running right last night, and am so pleased, as bar the engine mount noise, its running how i would like..
previously the vacum diaphram unit on the back of my replacement distributor had broken
, you could suck through it.. replaced it last night with the one off the old dizzy, and wow, what a difference. :lol:
idle used to mis behave at around 600rpm when warm, and nearly stall alot. fixed and the idle is now perfect 900-1000 and stable, it has also smoothed out neutral throttle driving which was like constantly being jiggled around, when your just coasting along.
Much better car to drive, shows what a tiny air leak, and lack of vacum advance will do to the engine. :angry:
ps this is an mi16 with 8v management.
regards
Justin
Jonmurgie
Nice one... good bit of fault finding you did there and as you say, shows how little things can have big effects!!
kyepan
well it was all you guy's on here that pointed me to the right location :angry: so thanks for all your help guys, much appreciated.
Regards
Justin.
