bitchass 205
Battery Light Coming On
bitchass 205
Hi all,
My battery light on the instrument panel is coming on when i'm at idle. Its very faint and doesn;t come on when car is at normal running speeds.
Could this be: Electrical problem?, which i doubt because knowing pugs it would be either on or off!
The start of alternator wearing out?
Or other problem which anyone else has had/heard of?
Any help would be greatly apprciated.
Michael
pa402
I had exactly same problem over summer and I needed alternator replacing. First check the charge to the battery. Mine was charging at about 11v and then got gradually worse with the light glowing all the time (noticeable only in the dark). New alternator solved it(until my other battery problems-see another post).
ashley peddle
sounds like alternator/belt issues. have you checked the belt? should be a little slack but you shouldnt be able to turn it more than 180 degrees... if not that then nab a volt meter and check its making the right voltage?
bitchass 205
Thanks guys, had a suspision that it might be alternator /belt problems. Will check tonight, where's best to buy alternator, and would you go for a refurbed one or new. I had a refurbed oone on my xs and it did ok, untill head gasket went!!
Cheers guys
ashley peddle
most people on here will probably have one floating about ^_^ or any breakers yards / 205 parts etc... i wouldnt bother buying a new one as they cost more than most 205's that are about these days :rolleyes::P:D
Rob Thomson
I had this on my 309 years ago when I was a poor student. Rather than replace the whole alternator, I just swapped the 'module' or whatever's it's called - essentially the bit under the plastic cover that contains the brushes, the regulator, and the thing that converts AC to DC - I should know what that's called but my brain's died. Anyway, cost me about £8 from my local ignition specialists. Bargain.
If its on an 8v you used to be able to get just the brushes kit so you didn't have to replace the whole alternator.
The drivebelt should only have about 2cm of play iirc at the mid-point on longest distance between pulleys, if it can be turned to 90' its to slack imo.
Older Haynes manuals even have a guide on how to do it. (its easy & obvious though).
Graham.
timmsy19
Graham.
i better give him his haynes manual back then :rolleyes:
ps. its is a standard 1.6 8v
justinv
had a similar problem on my 306 replaced alternator brushes and worked fine, don't need to change alternator
Guest smokinslim
Slightly off topic but on a similar note, i had my starter motor pack up a year or so back. Took it to my local auto electrical place where they charged about £35 to replace the bushes etc. A short while later i found that i could have got a complete reconditioned replacement off ebay for virtually the same money.
Having recently taken it apart myself i discovered i could have easily fixed it myself and i bet the parts don't cost half what i was charged, so it's definately worth looking into it.
