hexhamstu
Ignition Amp
hexhamstu
will it be 5-pin?
hexhamstu
so i've read that a 7pin one will fit no matter what, can anyone confirm this before i buy it?
hexhamstu
thanks for all the help....
I don't remember how many pins the ignition amp has off the top of my head, but the 8v and 16v amps are the same if thats any help?
hexhamstu
well on gsf theyve got 2 different ones for 405 mi16 and 205 gti 1.9 8v
they're wrong, someone else will confirm that they're the same soon I'm sure.
hexhamstu
hope so
paul205mi16
ive had both 1.9gti and got mi16 and both are the same part-bosch(posibly 7 pin) i would have to check! im sure ive seen this on another past topic aswell.try the search function.
hexhamstu
have done. i'm going with the 7
I had a look at the BX Mi loom I've got here & the ignition amp plug only has five pins to connect up so if they are in the right place then the five pin amp should be fine.
Check your plug & see if it matches the one you get, if not take it back as incorrectly supplied & get the right one.
