jim205GTI 3 Posted March 16, 2006 As i am sure most know the black and brown plugs are located at the opposite end to the ECU connector. Is it just a case of removing all the tubing and tape and then seperating the ecu connector and cables from the other ones ( not literally removing it ) and then just bringing it closer to the two plugs? Was thinking about this as i would ideally like to keep the Mi ECU in the same place as the 8v one And before any sharp replies come in saying use the search facilty.......... i have and trawled through alot of useful stuff i couldn't find the answer to what i needed Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted March 17, 2006 The way you've described is how I did the wiring on mine when I fitted the MP3.1 to my car. You only need to seperate out five or six wires unless you choose to use the 405 guages wiring afaik. Graham. Share this post Link to post Share on other sites
C_W 3 1 Cars Posted March 17, 2006 Really, what you're doing is bring the brown and black plugs closer to the ECU not the other way round (least that is what I did with the 405 loom) Basically stripped back each of the wire as far in to the loom as they would go from the black and brown plug (you need to cut these off as you can't use these anyway), and joined them up to the corresponding wire from under the 205 dash; of course, this assumes your original loom (engine and instrment) all goes through the bulkhead near the steering column). I found a lot of the wires from the plugs could be undone and didn't need extending other than joining up to the plug. Share this post Link to post Share on other sites
jim205GTI 3 Posted March 17, 2006 Haha i looked at the loom after i posted it and thought hmm i got that i bit backwards cheers guys just what i needed to hear!! my weekend task now lies ahead ....just trying to remove the original loom from the car luckily it goes through the bulkhead below the steering wheel Share this post Link to post Share on other sites
