m_attt 31 1 Cars Posted March 14, 2006 hi ive got a xm turbo lump in my garege with the loom and ecu, but its basically a bare block got f***ed over on ebay so i need loads of parts like sensors an air flow meter, boost pipes etc. so i was wondering can you get a mainfold for carbs and wot sort of works nvolved as it would ditch the injection and solve most of my probs. cheers matt Share this post Link to post Share on other sites
mbayley77 0 Posted March 14, 2006 I have seen carbs used on turbo'd cars but think i am right in saying that some things need changing as carbs usually work under vacuum conditions (for the ventury effect), but a turbo is running under pressure. Needs to have the turbo pumping the air into an air box also for distribution through the carbs obviously. Sorry for the vague post but there must be stuff out in the google world on this type of conversion. Good luck cos it sounds like a great project to me. Share this post Link to post Share on other sites
sonofsam 5 Posted March 14, 2006 must admit to knowing not alot when it comes to a Carburetor turbo set-up. good description here though Looks like a good read. Share this post Link to post Share on other sites
Ryan 99 Posted March 14, 2006 Apparently DCOE carbs were originally designed for forced induction, so require only a few small changes to the setup. I know you need a variable rate fuel-regulator which will keep the fuel pressure a certain psi above boost pressure. Share this post Link to post Share on other sites
rjw205 8 3 Cars Posted March 14, 2006 There's a dude called Paul, who i think is on here now and again, who has a carbed, turbo'ed mi16, in his 205. Was converte by Norris Motorsport. Have a look on the Norris Motorsport website. Google will find you this... Search away, and good luck Rich Share this post Link to post Share on other sites
rich_w 0 Posted March 14, 2006 I think you would be better off with some form of aftermarket ECU, megasquirts aren't too much money and you can do most of the mapping your self. The other reason common options are Emerald, KMS and Omex. KMS can controll the boost as well (unsure of the others). Share this post Link to post Share on other sites
veloce200 3 Posted March 14, 2006 rich_w said: I think you would be better off with some form of aftermarket ECU, megasquirts aren't too much money and you can do most of the mapping your self. The other reason common options are Emerald, KMS and Omex. KMS can controll the boost as well (unsure of the others). A decent rolling road weber specialist could get it working if you built it and pottered their with no boost but you'd still need electronic boost controller for best results and get an EGT gauge just in case one of floats sticks! Personally I'd go the EFI route. Money you save on RR'd could get you a wideband controller. I am an Emerald and now KMS dealer so can provide answers to any questions you may have about these. Share this post Link to post Share on other sites
m_attt 31 1 Cars Posted March 15, 2006 thanks for all the replys, id guesses i need an airbox for the turbo to run to, sorry i didnt explain properly i have the ecu an wirining, but im missing all the ancilleries, all the metal and plastic turbo pipes, all the coolant pipes, vaccuum pipes, airflow meter etc etc. im in no need or rush to do anything with the engine an as it is its worthless to me so its an ideal project to do, so any more info would be great, thanks again, matt Share this post Link to post Share on other sites
rich_w 0 Posted March 15, 2006 Just get some samco hoses (or something simlar) - you would have to get these anyway. Coolant pipes - well you would need these even if you went carbs... Maybe some on your 8v would fit? Vaccuum pipes shouldnt be too hard either. Airflow meter - Doesn't the turbo engine use a MAP sensor instead? It doesnt sound that bad.... Share this post Link to post Share on other sites
Henry Yorke 269 3 Cars Posted March 21, 2006 I have an inlet manifold and throttle body for one of these engines if it is any use? Drop me a PM or email chairman@psooc.com if it is. They do have a MAP sensor which is why your ECU has a pipe that runs to it, so no AFM Share this post Link to post Share on other sites
