miamistu 1 Posted March 12, 2006 Hi, does anybody know if the following is the correct wiring for a coilpack off a 106 xsi? PIN 1 ~ PIN 2 ~ PIN 3 ~ PIN 4 earth to cylinders 1&4 ~ earth to cylinders 2&3 ~ 12V ~ 12V Thanks in advance Share this post Link to post Share on other sites
M3Evo 0 Posted March 12, 2006 Might be an idea to put your old battery on charge Stu so we can test the coil pack just to confirm what does what Share this post Link to post Share on other sites
16v205 9 Posted March 12, 2006 I had an issue with a pug 406 coil pack, didnt realise it until once we got to emerald for mapping. When the pack was first wired up, it appeared to fire the correct pair of plugs at the right time, all seemed ok. Drove ok on part throttle but it was never under real load as it was an unmapped engine. Under load on idle though cylinders 1 & 4 were igniting unburnt fuel in the manifold. Turned out I'd wired the coil earth correctly for cylinders 1 & 4 but had crossed a 12v+ and earth for 2 & 3 around. When cylinders 2 & 3 were igniting the voltage was running the wrong way through the coil and sometimes igniting 3 or all 4 spark plugs. If its any use ill pin out the positive's and let you know tomorrow. Rich Share this post Link to post Share on other sites
miamistu 1 Posted March 13, 2006 That's great - cheers Rich! Share this post Link to post Share on other sites
16v205 9 Posted March 14, 2006 Hi Not had chance to get out to the car yet. Ill be back from work early tomorrow so hopefully be able to pin it out then. Rich Share this post Link to post Share on other sites
miamistu 1 Posted March 14, 2006 Okey dokey - no worries Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted March 18, 2006 Is the 106 coil pack you have the same as in this picture? If it is (ones I've seen are) the pin out will be the same as on my Mp3.1 & I can have a look at that if you want. Graham. Share this post Link to post Share on other sites
M3Evo 0 Posted March 18, 2006 (edited) Unfortunately not, mine looks like this: Thanks for the offer though. (this is stu) Edited March 18, 2006 by M3Evo Share this post Link to post Share on other sites
