Tidy_Andy
Mi16 - Jenvey Fuel Rail Length
Tidy_Andy
does anybody know what length the tube between the two parts of the fuel rail needs to be on an MI16 with a longmans manifold? spent hours getting the airbox an horns onto the throttle bodies and dont really want to take them back off to measure the spacing between the bodies
Bonzai
the one on mine (dino's old ones) is 78mm
Jonmurgie
It's covered in the 'Fitting Jenveys' article on the main site and the Emerald site (done by Dave Walker). The length is 77mm... I recently did this and it was spot on :) Also, use a bit of vaseline on the ends of the tubes as it helps then get past the o-rings inside the fuel rails. Oh, and make sure you file the ends of the tube!
Tidy_Andy
didnt realise there was a fitting guide!!
will take it into work an get it cut on a lathe, they can radius the ends at the same time to avoid splitting the o ring.
have to hope kimi an montoya dont have a bad weekend so there quiet in the machine shop :)
