Guest ronnie69
Twin 45's And Alternator
Guest ronnie69
I have a 309 gti that I am in the process of fitting twin 45's to.
It has power steering which I plan to junk and move the alternator to the lower non-pas mounting position to ensure the inlet manifold clears the alternator.
Is the pas bracket usable for the alternator or do i have to find a specific lower alternator monting bracket??
If so where can I get one??
Chris
Just get the mount and bracket from a non-PAS 205 or 309 1.6/1.9
You'll also obviously have to buy the non-PAS alternator belt as well, as the PAS one will be far too long.
mfield
If you are using the magolesti (sp) inlet manifold you will need to remove metal even from the non-pas upper alternator bracket before fitting, you might want to shorten the two end studs aswell.
Kitsune
Chris, I'm not sure what make that inlet is (came in the Webcon kit I believe), and it was a straight on fit on my old 8v (non pas).
I'll be interested if you do have any fitting problems (ref removing metal).
NNN
What about fitting twin carbs without removing the pas??
Guest ronnie69
thanks for your help chaps. It is proving difficult to find anyone with the non PAS alternator bracket.
Does anyone know anywhere I can get one other than the £30 direct from peugeot??
Guest ashnicholls
do the webers not fit with PAS alternator bracket?
has anyone got one?
