smighall
Rear Hubs
smighall
Hi there, i'm relatively new here, and this is my first true post, so hopefully somebody can help me.
I'm thinking of converting my 1.6 beam to a 1.9, and i've looked through as many other threads as i can find regarding this. My main question is, do any other cars share the same rear hubs or stub axels as the 1.9, as i don't think i'm going to find a 1.9 in a scrappy with the rear beam still in tact.
I am right in thinking the rear calipers are the same throughout most of the peugeot range, aren't i?
Sean
Hilgie
Yes, both calipers and hubs can be swapped from a 306 to a 205.
Guest rick03054
Are there many other models that share the same hub?
Guest smokinslim
Not 100% on this but pretty sure that citroen ax/zx 's are worth a look.
Guest rick03054
What about the newer ones? I was thinking along the lines of scavenging 206, 307 etc.
Guest smokinslim
This thread may be of interest to you: clicky
discussing the posibility of fitting trailing arms from various models to the 205 beam.
smighall
Cool, thanks guys
