pablo
Oil Cooler Fitting Q
pablo
Hi all got an OE cooler for the Mi16 (off a 1.9gti afaik) but we dont have a coupler to screw into the block (going thru the sandwich plate)so that the oil filter can then screw to (if that makes sense)
any ideas where I can get one?
thanks all
-paul
Jonmurgie
I assume you have the oil-air cooler and not the oil-water cooler? In either case it would be easiest to get the bit you need from someone breaking an Mi16... if it's the oil-air then you should be able to get the take off plate from Mocal (think automotive are the main UK distrubitor for Mocal).
Ahl
You're best bet is the wanted forum Paul.
You'll have access to this when you become a driver member (30 posts).
Topic locked to prevent it becoming a wanted post.
Guest
