Guest bernieslaven
Any Old Interior Into 205?
Guest bernieslaven
i would like to know if anyone has ever modified interiors from other cars to fit their 205?
I dont know anything about sub frames (other thn it must be the part that fixes to the 205 floor) or how sub frames may differ from different car manufacturers. Have been searching on ebay for a full leather interior and there are plenty of full leather interiors going - in particular there's a Citroen set with electric heated/moveable seats which requires a connection to the battery - is this possible?
Any advice would be gratefully received - i am assuming that as long as the dimensions of the seats 'fit' inside the 205, its just a matter of bespoke fitting with a couple of extra nuts/bolts.
DT
M@tt
have a look at my sigs for my pics as i've fitted full leather from seats from a fiat coupe and am fitting a 206 dash
none of it was straightforward ;) the seats needed brackets welding as the subframes were thinner than the 205 ones.
slider2
i think anythings possible as long as you are determined enough ;)
