Owain1602
Which Engine Code?
Owain1602
I just got another engine for my 205 but im curious as to which engine code it is. Its from a J reg car which i thinks the original engine, the plate on the engine isnt there, its got no spacer by the sump. I want it to be just a 115bhp 1.6 engine i hope it is. Its got the coil mounted on the Inlet manifold.
Also, the one i currently have has the 3 pin plug from the dizzy going to the ignition module mounted on the plate with the coil. but the section of cut loom i have with this new engine has the 3 pin plug going to another black plug which goes in with the main wiring loom. does it go to the ECU? If so, will i have to get the ECU that was run with the engine or is there another way?
Thanks for reading.
